1998 CIVIC SWAP B16A2 not starting ...
Discussion in 'General Tech and Maintenance' started by Marius850r, Aug 11, 2016.
  1. Marius850r
    Marius850r New Member
    Hey everyone and thanks for the future help
    Got an Ek 1998 and swaped an B16A2 with ( p28 ecu ) , used the 98 wiring harness + ecu jumper harness OBD2A to OBD1 , car cranks but no spark , I wired the Dizzy color coded but I feel like I am missing something and don't know where to go ...... I wanna see it running :( need some help from u guys !!
  2. awptickes
    MD
    To recap:
    You swapped a b16a2 into your 98 EK
    You used the existing harness
    You used a jumper to go from OBD2a to OBD1 for the P28 ECU
    You repinned the distributor for the new ECU
    Car doesn't get spark
    Do the injectors fire?
    Have you traced the distributor wires all the way back to the ECU?
    dilbeckskate likes this.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Rewire the distributor.....I thought that was unnecessary for a B series in an EK. Straight plug and go. Only wiring is a knock (if not deleted in chip) and VTEC (if it's not an EX).
  4. Marius850r
    ( NO )
