not too sure about how your mounts work but i will try to give you approximates...
you have a 98, so i think thats OBD2 right?
so i think your B16 swap would run upwards of 1800 approx
you could prob use junkyard mounts from a wrecked B16 teg...
B18B would give you 140 horse, swap goes for around 2200 from hmotorsonline.com, but prob cheaper from a local junk yard...
and again use B series mounts from a stock teg
H22 would yield 200 horse for around 2K, but then you need mount kits and lots of wiring and customization... axles, shifter cables, etc... you can get the H22 in OBD2... not sure what version your car is...
turbo kit could be built for less than 2K, i think greddy has a bare bones kit for under 2K, no intercooler or anything fancy with it...
check out homemadeturbo.com
you could use an HF manifold on your D series motor, with an adaptor plate, first gen eclipse turbo, junkyard intercooler, fmu, oil feed lines.... etc etc etc
read up on this site and any other honda site to get a better idea of what you wanna do... make sure you have the skills to handle whatever you are planning...
check your local junkyards and see if they have a wrecked integra, even if its just a B18 non vtec swap, it'll be fast and prob cheap, and everything you need for your swap will be right there...
where are you from? if you come across cheap motors at your local junkyards let us know, i;m sure someone would be interested if your locality hasn't been overpriced by the honda craze
your car is right hand drive?
