1999 Civic D-Series Transmission Options
Discussion in 'HYBRID -> EG-EK / DC' started by Draftinwitjr3815, Feb 10, 2013.
  1. Draftinwitjr3815
    Draftinwitjr3815 New Member
    I guess this is technically a "swap" issue.
    I'm having a hard time finding information on what other manual transmissions I can use in a 99' Civic Coupe EX with the D16Y8. The transmission makes a grinding noise going through 1st gear.
    What I want to know:
    I have a manual trans from a 93' Civic EX with the D16Z6. WILL I BE ABLE TO USE THIS TRANS in my 99'?
    They physically appear to be the same, same mounts, etc.
    Do they use different spline axle shafts? Are the clutch and flywheel sizes the same/interchangeable? Will I have to use the 99' VSS and will it fit in the 93' trans?
    Any help is greatly appreciated! Thanks!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes its a direct swap. plug and play.
  3. Draftinwitjr3815
    I am very glad to hear that!
    I guess my only other question would be is this the same as if I wanted to swap a manual trans from a D15B7 into the 99'? I think it should be.
  4. AHHVTEC
    Alabama
    yes all d series from 88-00 will interchange, but the 88-91 are cable trans, the only difference is going to be with the gearing. your best bet would be to get one from a ex or si model 92+ years. the others will work but the gears will be longer.
  5. Draftinwitjr3815
    Thanks for your help and quick response!
  6. AHHVTEC
    Alabama
