1999 civic dx HB
Discussion in 'Civic and del Sol - EG and EK' started by joebig585, May 17, 2008.
  1. joebig585
    joebig585 New Member
    Hello my 1999 civic hatch DX motor has taken a crap, Its a non vtec i believe its the d16y7?.
    My goal is: keep an auto trans and a low cost.
    What motor should i put in i was thinking a d16y8 and wire up vtec with a new ecu and harness. Would there be a better motor for my needs?
    Also dose a d16y8 bolt up to the d16y7's auto tranny?
    Thanks so much im new to civics so... sorry for the noob questions.
    Joe
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just get the d16y8 vtec motor run a few extra wires useing your stock dx harness and yes it will bolt up to your dx auto tranny and all easy swap it will drop right in. but unless your gona mod it a perty good bit , i would just put another y7 in there
  3. joebig585
    Thanks for the quick response,I really appreciate you help and knowledge.
    I plan to do intake exhaust and maybe a cam and down the road a turbo.
    Should i go d16y7 (nonvtec) or d16y8 (vtec) with those mods.
    Thanks again so much
    Joe
  4. AHHVTEC
    Alabama
    well in that case just go ahead and get the y8
  5. joebig585
    Right on. Thanks;). Hopefully now i wont get smoked by my friends GTI MKV
  6. AHHVTEC
    Alabama
    you will handle him just fine, there really not that fast unless the ecu has been chipped
  7. joebig585
    Hes bone stock, Its good to know that.
    One more question. Do you happen to have a write up or some type of info to run the vtec wires off my stock non vtec harness?
  8. AHHVTEC
    Alabama
    naa not me but theres tons of info on that in here just try the search box because im not for sure where its at, but its real easy its like 3 wires.
  9. joebig585
  10. BrutalB83
    Rochester Hills, MI
    Just FYI, automatic Civic transmissions tend to break when you start putting a significant amount of power over stock (i.e. boost) through them...
  11. joebig585
    Guess ill have to do the auto to manual conversion before i boost it.
    Going to buy the parts tomorrow just double checking, Tell me if im missing anything or something is wrong for my D16Y7 to D16Y8 swap.
    D16Y8 motor
    Civic Ex harness
    Civic Ex Auto ECU
    Thanks so much for all the information
    Joe
  12. AHHVTEC
    Alabama
    you really dont need the ex harness but it would maker it easier other than that looks good
  13. joebig585
    Ok thanks. motor swap here I come :D
  14. eg6dx97
    eg6dx97 New Member
    Ya if he flashed his ECU lol those things can cook after an ECU flash
  15. eg6dx97
    eg6dx97 New Member
    i dont think you need a new Trans ECU u should just need the engine and the engine ecu
  16. eg6dx97
    eg6dx97 New Member
    u can use your existing harness.. i used my existing harness and i did a b16 swap i had to do some wiring but it wasnt that bad
  17. |Chaz|
    |Chaz| Well-Known Member VIP
    Jeezus titty fucking triple post.
  18. BrutalB83
    Rochester Hills, MI
    Who said he needed a transmission ECU? No one did, to my knowledge...
    How do you figure a bone-stock single cam with an automatic transmission is going to "cook" after a simple ECU flash? Or are you talking about the GTI?
  19. eg6dx97
    eg6dx97 New Member
    ahh another forum i found.. wow Now he was trying to test his Wisdom on VWs!!!
    Again i Apologize for any one for the previous posts were done by my retarded friend that got on my account because he forgot his own password. He seemed to want to spread his misleading wisdom on all car things perhaps in an attempted to Confuse every one
  20. AHHVTEC
    Alabama
    not to be rude but no one is gona believe that shit your best bet is to start all over with a new user name
