1999 Civic Si motor swap
Discussion in 'ECU's, Electronics, and Tuning' started by blueSi, Jun 1, 2005.
  1. blueSi
    blueSi Junior Member
    I recently bought a 1999 Civic Si that already had a swap done. It is a OBD1 b16a2 i do believe. anyways, i am having trouble getting the car inspected because the inspection computer wont comunicate with the car. Is there anything i can do? I need some suggestions.
  2. jamesA
    b16a2s are obd2b, and they're the stock engine. Do you know what ecu is in there though? 99-00 Si ECUs are p2Ts.
  3. blueSi
    the engine and ecu are out of a sirII. im not sure off the top of my head what it is. i would have to look.
  4. blueSi
    the ecu is OBDI P28
  5. jamesA
    I'm not familiar with inspection computers or how they hook it up since Indiana doesn't have inspections. Are there different connectors for obdI and obdII? They might have just been using the obdII connections if there are.
  6. blueSi
    well when they hook everything up the computer recognizes the car as obdII because of the year, however, when they hook it up to the car it doesnt do anything. I dont know if it is because of the engine managment it has or what. I am kind of stuck between a rock and a hard place.
  7. jdmeg6
    jdmeg6 Senior Member
    So Cal
    So you say that its already had a swap done to it. Are you for sure that it's a B16A2 under the hood? If so, thats the stock motor and no swap was done to it, or if there was a swap done to it they just took the motor you have now out while the real swap was in place. Almost sounds like it's a B16A
  8. blueSi
    yes that is what it is. A JDM B16A SiR-II motor swap
  9. jdmeg6
    So Cal
    I think that they just need to test it as an OBD-I equipped vehicle instead of thinking that it is still using the stock setup which was OBD-II. By the way, what state is this in?
  10. blueSi
    North Carolina
  11. jamesA
    That's what I was getting at myself. Go in there and tell them it's an OBDI ecu/engine setup and have them test it that way.
  12. blueSi
    cool, i will havee to try that. thanks for the help
  13. 94accordex
    94accordex Member
    Has anybody noticed that this shit is in the wrong forum?
  14. jamesA
    haha I did after I couldn't find it.
    I IMd a mod but he was off playing some game.
    IM'ing another mod...
  15. spectacle
    spectacle Senior Member
    St. Petersburg, Fl
    If you have a P28 ECU in your car it is no longer OBD2 to any diagnostic tool. The OBD2 port they use to plug into your car will not work.
  16. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Did it get moved? Because it is in the right forum.
  17. pissedoffsol
    get a p2t and plug it in.
    with the p28 thats in there now, there a good chance a knock wire was never hooked up, so it may throw a code for that. double check that its hooked up.
    like said, the p28 is obd1 and doesn't have obd diagnostics features (like the scan tool) that obd2 has
  18. jamesA
    Yeah, after I pm'd jamie and Brian both someone finally moved it... it was in auto appearance.
    edit: I'd like to know if scanning it as obdI worked for him.
    If not B has a good suggestion.
