1999 honda civic ex brake light problem
Discussion in 'Civic - EP, FA, FG' started by orangemanja, Dec 23, 2007.
  1. orangemanja
    orangemanja 99exturbob16aswap
    usa
    Whats up everybody!
    I have a 1999 civic ex with a turbo b16a2 swap
    I had the engine rebuilt (to much boost blew a piston) anyways when i got the car back the brake lights didnt work anymore. Iv checked the fuses,light filiments,and connections in the trunk. What else can i check and where is it located?
    ( also the turn signals and running lights are working )
    Let me know what you think
    thanks
    jason
  2. whiterabbit06
    Crestview, Fl
    You can check the brake switch. It's attatched to the brake pedal assembly under the dash. Unplug the switch and use a wire to jump the two pins. If the lights turn on it's the switch.
