1st swap need help
ratchetratchet
alright im in the middle of this and need some help i took a b16a out of a 91 crx and am trying to put in a 92 si i think i have all the wiring done but the crx mounts wont work i need to know what engine/tranny mounts i need.also will the axels that came out of the crx work in the si
thanks for any help
first question, did you change your tranny over to a hydraulic one? Because the cable tranny will not work in the 92 civic without modification,
Also you will need engine brackets and mounts from a 1994+ integra.
the axles should work in the 92
