Hey just wondering if i can stroke my engine (B18C1) to a 2.2L :unsure: ????? Also, will the engine be just as reliable as it is now, and approx. how much HP will i gain from it. (assuming i have the usual I/H/E)
he was askin' 'bout stroking... not boring. with it sleeved, bored out to 85mm and with a 95mm stroke you'll be at 2156cc. i wouldn't bore any larger than that, and i'm not sure how big you can stroke it. check out crower's stroker kits... http://www.crower.com/cat/import/honda/stroker.shtml .
the displacement wouldnt be the prob w/that setup for street its got more to do w/compression ratios and lack of emissions equip not to mention I'm fairly sure Eric's engine would die on pump gas.
you could run a 2.2 b18 on the street w/many setups and if you have the kind of $$$ to stroke it that hard you prob have enough to do the rest that would require.
