mikey bottles
Prof. Bottles
1993 Honda Civic LX 1.5L 5spd. New head gasket, timing belt, water pump, intake/exhaust mani gaskets, thermostat, new distributor, cap, rotor and wires. Needs two 13" tires for the front. asking $1400 firm.
1988 Honda CRX Si- B16A swap with Y1 trans (no lsd), PW0 ecu, Walbro 255Lph fuel pump, Skunk 2 Pro-C full coilvers, Skunk 2 Mega power cat back exhaust, OBX Hi-Flow Catalytic Converter, Rear disc brake conversion, 4 new 185/65R14 Kumho KH18's, 'ZC' Style Seibon carbon fiber hood, Blox rear LCA's (gold), Phase Linear in dash 7"flipscreen cd/dvd player, Skunk 2 Shift knob, Skunk 2 billet spark plug wire cover, Skunk 2 10th anniversary oil cap, Skunk 2 Radiator cap, Skunk 2 VTEC solenoid cap, 2 pair of Kenwood 6.5" 3 way speakers 200 watt, AEM short ram intake, Megan Racing adjustable cam gears, Samco Sport radiator hoses (blue) new timing belt, water pump, fuel filter, spark plugs, wires, distributor cap, rotor, new inner & outer tie rod ends, new upper control arms, new lower ball joints, new axles, new left side axle seal, Halo projector headlights, Amber side corner lights. all side moldings are new from Honda, including the front section of the side skirt. Car has fresh oil change, and fresh alignment. Has the typical honda drivers seat tear, and rear quarter panels were repaired but showing signs of rust again. I'm pretty sure that covers everything. Also for whoever buys the car it WILL come with a fresh 2 year NJ State Inspection sticker!!!!!!!!!! asking $4,000 obo
I leave for california for 10 days tomorrow morning, but hopefully i will be able to check this while there and answer any ?'s if not i assure you i will promptly get back to you when i return on nov 6th. You can PM me here with any ?'s or email me at mikeybottles@hotmail.com (be sure to make the subject of the email which car your interested in) if you would like you can try and contact me at 856-264-6462. Thanks for looking!
