2 different subs
Discussion in 'Car Audio / Security / Electronic Accessories' started by Feudal, Feb 24, 2009.
  1. Feudal
    Feudal New Member
    is it will be ok to run 2 different subs? with close specs but not 100% identical
  2. MthaFuknGreen
    Lodi, CA
    lol
    yeah, but it might look and sound kinda funny.. really depends on the differences.
    might sound even better then two identicals.
  3. Feudal
    Feudal New Member
    how come? saw something like that?
  4. Matts96HB
    Matts96HB . Moderator VIP
    You can, but it is going to be tricky to get it to sound right. If you run them off of two seperate amps, you need to be careful or you will experience cancellation. The best idea here is to run them off of the same amp, and make sure you stay right around RMS on the sub with the lowest RMS rating.
  5. MthaFuknGreen
    Lodi, CA
    how come what?
    why would it look funny?
    i dunno, i just think it would.
  6. Feudal
    Feudal New Member
    no how come it will sound better than twins:huh:
  7. Feudal
    Feudal New Member
    same amp with same channels? or for example 4 ch amp with bridged 1/2 3/4
  8. MthaFuknGreen
    Lodi, CA
    i didnt say it would.
    i said it might, it might not...
    the two different subs specifics could compliment each others sound, or they could cancel out each others sound.
    yes, thats what hes saying.
  9. whiterabbit06
    Crestview, Fl
    If the box has a piece of wood separating the two subs, ie two separate chambers, then it doesn't matter. If it's one big open space for the both then they have to be really close, otherwise the stronger of the two can damage the weaker.
  10. Taco15
    Tallahassee Fl
    correct sir. as long as they are in their own chambers its fine. if they are going be powered by amp...they should..make sure they are wired so the amp can see an even ohm load like 2 or 4 ohms.
    i burnt up my amp because i bridged 2 identical svc forsgate subs. i never noticed that one was 4ohms and the other was 2ohm.
  11. MthaFuknGreen
    Lodi, CA
    then they werent identical sir..
  12. Taco15
    Tallahassee Fl
    you know what i meant smart ass. identical in looks.
