2 questions one regarding rpm drop
Discussion in 'General Tech and Maintenance' started by sleepn_accord, Jan 21, 2004.
  1. sleepn_accord
    sleepn_accord Senior Member
    O.k.
    93 accord and an h22 with a/t.
    I had this problem with my stock f22 and still have it: when I'm going uphill around 60-70 mph and let off the throttle and then push it down 1/4 way the rpms drop about 300, but if I let up a little bit (to about 1/8 throttle) the rpms go back up.
    So cruising say I'm at 3000, 1/4 throttle it goes down to 2700, let off the throttle a little bit to 1/8 throttle and the rpms go back up to 3000.
    WHAT GIVES!?
    fuel filter & o2 sensor have been changed.
    Problem #2.
    My trans only shifts at 6500 now when it was shifting at 7200 before... <_<
    thanks.
  2. cws13
    cws13 Senior Member
    Athens,GA
    Is it dipping for a second, or if you don't let up the said 1/8, will it stay 300 low. If only momentary, this is normal lag for the torque converter.
