2 questions?
Discussion in 'Civic and del Sol - EG and EK' started by old-noob, Apr 22, 2009.
  1. old-noob
    old-noob New Member
    I have a 95 ex coupe d16z6, manual tranny.
    1. I just swaped in a set of gr2s, & Tein S tecks, but I occasionally get a rattle from the right side. ( both front & rear ). Every thing is torqued to speck, any ideas what I may have missed?
    2. Is their a speed govener on a d16z6? It pulls to about 118 @ about 4400 rpm then just stops accelerating. The Vtec doesn't kick in in 5th gear. Is this normal?
  2. rkwoos12
    rkwoos12 New Member
    Kentucky
    i got my 94 civic ex with d16z6 engine to do 125mph no problem, it is stock, and i belive vtec kicked in not for sure.
  3. efhondakid
    Akron-Canton, Ohio
    Yeah it only goes 118 because its all out of juice. What more do you want from a 120hp 1.6?
  4. old-noob
    old-noob New Member
    I was just surprised it stopped at 118 because it got there easily. Really thought it was odd the V-tech didn't kick in.
  5. dcasey12
    dcasey12 New Member
    Whats the gearing?? thats only 2200 odd at 60mph, are you running 18" wheels or something, the gearing is all wrong or your guages are out, it should be able to pull 5-6000 rpm in 5th if it has the proper gearing, although the speed is close to the mark the tacho is way out.
  6. old-noob
    old-noob New Member
    To my knowledge the car was bone stock when I bought it, so it should be the typical ex tranny. In 1-4 power starts dropping off about 6000, & the rev limiter is around 6500. (only hit it once). I'm running 15'' Konig Minuz wheels & 195/50/15 Kumhos.
  7. dcasey12
    dcasey12 New Member
    Sounds like your tacho is out, it should pull to 7000 odd and rev limiter would be probably around 7200, the speed you are getting sounds right, get your tacho tested.You probably just dont feel the vtec kick in because its under such high load at that speed theres no power surge you notice in lower gears.
  8. serrilion
    serrilion In my own little world! VIP
    Vermont
    Thought it had like 127 ???? and no it stopping at 118mph? wtf? I have a vid of my 95 ex doing 125 and it had plenty left to give... intresting
  9. frodotoolbox
    frodotoolbox 92 civic si d15b
    sc
    i had my del sol to 144 and it still had some left.
    well i do redline at 7200... and weigh a little less but still.........
  10. dcasey12
    dcasey12 New Member
    Thats 240kmh!! which cliff did you push it over, the grand canyon. Make sure you have your hand on the right stick, its the one with the numbers 1 to 5 on it.
  11. frodotoolbox
    sc
    i was on the highway going home from work at like 2:30 in the morning and saw a police speedo thing and decided to just drop it and go...
    i was in fifth at about 6000-6200, wasnt really paying attention to that, and the sign was blinking red 144 and i started to slow down.
    my car has no carpet and nothing in the trunk. and i have a fully headerback custom exhaust, cia, and a slight tune by one of my buddies at my local tuner shop.
    oh and a stage 2 ACT clutch kit. pressure plate/flywheel/clutch
  12. BrutalB83
    Rochester Hills, MI
    I'd be willing to bet that the weight of a Del Sol is similiar to, if not more then, a 92-95 Civic coupe...
  13. nofxSOHCcrx
    nofxSOHCcrx New Member
    Las Vegas, NV
    1995 Models
    DC 1995 Acura Integra GS-R Coupe MT 2667
    DC 1995 Acura Integra LS Coupe MT 2643
    DC 1995 Acura Integra RS Coupe MT 2529
    DC 1995 Acura Integra SE Coupe MT 2643
    DC 1995 Acura Integra GS-R Sedan MT 2765
    DC 1995 Acura Integra LS Sedan MT 2738
    DC 1995 Acura Integra SE Sedan MT 2703
    1995 Acura NSX MT 3047
    1995 Acura NSX AT 3113
    1995 Acura NSX T AT 3208
    1995 Acura NSX T MT 3142
    EG 1995 Honda del Sol S MT 2295
    EG 1995 Honda del Sol S AT 2387
    EG 1995 Honda del Sol Si MT 2414
    EG 1995 Honda del Sol Si AT 2474
    EG 1995 Honda del Sol VTEC MT 2522
    1995 Honda Civic CX HB MT 2108
    1995 Honda Civic DX HB MT 2178
    1995 Honda Civic DX HB AT 2264
    1995 Honda Civic Si HB MT 2390
    1995 Honda Civic VX HB MT 2094
    1995 Honda Civic DX CPE MT 2231
    1995 Honda Civic DX CPE AT 2326
    1995 Honda Civic EX CPE MT 2443
    1995 Honda Civic EX CPE AT 2502
    1995 Honda Prelude S MT 2809
    1995 Honda Prelude S AT 2862
    1995 Honda Prelude Si MT 2866
    1995 Honda Prelude Si AT 2921
    1995 Honda Prelude VTEC MT 2932
    1995 Honda Accord EX CPE MT 2954
    1995 Honda Accord LX CPE MT 2822
    1995 Honda Accord LX CPE AT 2888
    DC 1995 Acura Integra LS Coupe AT 2685
    DC 1995 Acura Integra RS Coupe AT 2570
    DC 1995 Acura Integra SE Coupe AT 2685
    DC 1995 Acura Integra LS Sedan AT 2780
    DC 1995 Acura Integra SE Sedan AT 2708
    EG 1995 Honda Civic DX SDN MT 2313
    EG 1995 Honda Civic DX SDN AT 2392
    EG 1995 Honda Civic LX SDN MT 2376
    EG 1995 Honda Civic LX SDN AT 2440
    EG 1995 Honda Civic EX SDN MT 2522
    EG 1995 Honda Civic EX SDN AT 2575
    1995 Honda Accord DX Sedan MT 2800
    1995 Honda Accord DX Sedan AT 2866
    1995 Honda Accord EX Sedan MT 3009
    1995 Honda Accord EX Sedan AT 3075
    1995 Honda Accord EX V6 SDN AT 3285
    1995 Honda Accord LX Sedan MT 2877
    1995 Honda Accord LX Sedan AT 2943
    1995 Honda Accord LX V6 SDN AT 3218
    Check for your self
  14. BrutalB83
    Rochester Hills, MI
    Yes noob, I know where the FAQ section is. I've looked at it many times myself, and that's why I can say off the top of my head that the weight of those two cars is going to be similar...
  15. frodotoolbox
    sc
    i dont have carpet or passenger side air conditioning stuff in my car. and my trunk is 100% empty. well except the brackets thats supposed to hold the roof holder.
  16. efhondakid
    Akron-Canton, Ohio
    And all that stuff weighs <20lbs. Your not gaining anything.
  17. Del Sol Bum
    Del Sol Bum New Member
    Yall need a room?????
  18. nofxSOHCcrx
    Las Vegas, NV
    Whoa there dude, I was in NO way saying search the forums, I just put that up so it could be proven in this post...I could see the confusion with "check for yourself" but wasn't saying like that.
  19. BrutalB83
    Rochester Hills, MI
    Gotcha. Sorry if it seemed like I was snapping at you...
    Really? That's your first post here on this site?
  20. nofxSOHCcrx
    Las Vegas, NV
    No Problem.
    LOL
