2000 civic si tranny on b18a1
jordan
ok i am planning on putting a 200 civic si tranny on my b18a1 that i am swapping into my 94 dx. what flywheel clutch and throw out bearing should i use? :worthy:
you do realize that your car and trannythat you want to use is a hydraulic tranny and the b18a1 motor uses a cable tranny. Not to mention that your 94 model car is setup for a hydraulic clutch. If you haven't already got the motor get a b18b instead or try to trade. It would be much easier.
yeah i know that the b18a used cable clutch but the engine doesnt have much to do with the hydraulic system. i just need to know if i use the b18a flywheel? and which clutch do i use the civic si? or the b18a?
pressure plate connects to the flywheel which connects to the crank of the block,
you don't go by tranny, but it's a b series so all is compatable.
I suggest an EXedy clutch and a fidanza
