here it is:
1. Turn key to 'on' position. The service reminder will start flashing.
2. Use the select button to toggle through the trip odometer readings, past th oil life indicator and back to the service reminder.
3. At this point, press and hold the reset button. You will be asked if you want to reset the service reminder. The default is "N".
4. Release the reset button and use the select button to toggle the selection to "Y". Press reset.
The oil life is reset to 100% and you are ready to rock.
