2000 dx coupe build
Brettmurphy96
So I currently have a 2000 dx coupe with a y7 and 5speed with just little stuff like integra seats, Acura el cluster and mirrors, short throw shifter.
I purchased a 95 Acura integra ( body is shot ) with a b20z2 on a b18 hydro tranny. The car has a obd1 b16 distributor on it right now and only has the top bolt in the dizzy so i dont think the timing it quite right but runs decent and it is running on a obd1 p75 ecu.
When i go swap this into my civic im going to use the integra shift linkage and inner cv joints on d series outer axles. Will have to order 99-00 SIR timing belt post and a rear t bracket?
But I am also wondering since my car is obd2b and the b20z2 is a obd2b motor would it be easier for me to run a obd2b b20z2 distributor and obd2b p75 ecu?
And i should be able to use most of my dx wiring harness and just rob a few connectors from the integra or will none of them work because it is obd1?
Welcome to the site :wave:
If my memory serves me correctly, only the distributor, injectors, and alternator plugs are different
So do you think i should stay with my obd1 p75 ecu and get a jumper harness or find a obd2b p75? And definitly look for a ob2b b20 distributor?
