I have not seen a whole lot about the Ody here but here goes. I have an Ody that will not start without applying some throttle. When not on the pedal it will try to start but the stall imediatly. If i give it just a little pedal it will fire up and run... until I come of the throttle it stalls. Truthfully it a won't idle problem that came across as a no start problem. Also what do I short out to pull code on this thing. I looked evey where and could not find a 2-pin connector. I do see a many pin connector mounted under the dash. on the drivers side of the console. Any ideas? HELP please.
