2001 4 cyl manual to v6 swap?
Discussion in 'Accord' started by mayen00, Jan 8, 2009.
  1. mayen00
    mayen00 New Member
    im getting a v6 motor i know the v6 models didnt come in manual but im wondering if the swap would work or would be worthless please reply
  2. 95b16coupe
    95b16coupe New Member
    ct
    what car do you have? why would you ask us about it after you have already decided on getting it?
  3. BrutalB83
    Rochester Hills, MI
    The engine you bought won't bolt up to the transmission that's in the car. You should have researched this before you started buying stuff...
  4. mayen00
    mayen00 New Member
    v6 swap
    my car is a 2001 honda accord 4 cyl 2 door the only reason i bought the motor is because i got the whole front end for $500 including trans and everything the motor only has 50,000 miles on it im wondering if my manual transmission will work in the car even if it doesnt work ill sell the motor and trans im just wondering if it will work or if i can make it work
  5. mayen00
    mayen00 New Member
    and if that doesnt work what tranny could i use to do it?
  6. BrutalB83
    Rochester Hills, MI
    Your existing transmission WON'T bolt up. It just won't. Not gonna happen. Your only option here would be to find a manual six-speed from a V6 Acura, the CL I believe. That's the only gearbox that's going to work, because it was designed for a J-series V6 (which is what you have)...
  7. 94H_Ex
    94H_Ex Under employed
    Florida
    considering this is in the accord section. Im guessing he owns a 01 accord.
    Its only a guess though :D
  8. 94H_Ex
    Florida
    Im curious. Whats his existing engine in his car now?
    Of course his 4 cyl tranny wont bolt up to that v6 but i think what he's asking is will the V6 manual trans that fits the v6 engine will actually fit in his car. most likely with out hasport mounts.
  9. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    a v6 in a 4cyl engine bay? is that possible?
  10. mayen00
    mayen00 New Member
    of course its possible its the same engine bay as the v6 but my engine now is 2.3 liter 4 cyl vtec 5 speed manual its really slow so it will work just get the cl tranny? i wanna keep it manual the transmission on the motor is automatic thanks for your reply guy
  11. mayen00
    mayen00 New Member
    hey do u think its worth putting that engine in there or should i just go with the h22?
  12. BrutalB83
    Rochester Hills, MI
    There was no manual transmission available for the 98-02 Accord V6. Like I said, the only option would be to use a transmission from the Acura CL since it also used a J-series engine...
  13. BrutalB83
    Rochester Hills, MI
    That's a toss-up. There's a lot more after-market support for the H22, but the V6 will probably outrun it stock for stock...it's got more torque...
