2002 civic radio wiring diagram
unix4linux
Hello,
I have been searching the web and various forums but cannot seem to find the wiring diagram for a 2002 civic for the radio. I have 4 wires from the stock harness that I don't know where they go on my aftermarket deck
red
blue/white
gry/red
white/red
If someone has the entire diagram and not just those four wires, that would be great but if someone can at least tell me what those are, that would be fine.
RADIO 12V|white/red |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA| | | |
| LF SPEAKER|grn/blk - lt green | |radio |
| RF SPEAKER|grn/yel - gry/red | |radio |
| LR SPEAKER|blu/wht - blu/blk | |radio |
| RR SPEAKER|pink - blu/yel | |radi
Thanks for the reply. That worked out great and I found out that the red wire was for my illumination ground. I added that to my other grounds and everything is fine. I did blow my 4 channel amp fuse so I had to replace that ;-).
Thanks again for the help
so i take it you dont have an aftermarket harness? If not i really suggest getting one. Even if your got it working fine. It make it easier in the long run when your changing out cd players.
Plug n Play makes things so simple.
