2005 Civic may be having issues
Discussion in 'General Tech and Maintenance' started by erikespo, May 16, 2005.
  1. erikespo
    erikespo Senior Member
    Western New York
    I haven't been too hard on my new car. Anyway Over the past 2 weeks the car has been requiring a few seconds with key the key in the start position to until it finally starts. Normally it was maybe about 1.5 seconds in the start position, now it is around 3-4 seconds. I believe this is only happening when the car has been sitting for a few hours.
    I changed the oil and filter. Changed the air cleaner. I only put 93 as well. I guess my next step would be to change the spark plugs. if that doesn't do it I will change the fuel filter. Anyone else have any ideas as to what else would be causing this problem?
    EDIT.. Just checking this.. For the plugs I am looking on www.ngk.com and it says the OEM plugs are "NGK Double Platinum 3271 PZFR6F-11 0.044 "Original Equipment Manufacture and/or Original Equipment Service part." $11.71"
    Kinda pricey I think
  2. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    New car? Trouble starting? Take it back to the dealer. It's probably under warranty, and won't cost you anything.
  3. APACHE
    APACHE Junior Member
    ATLANTA, GA
    I agree w/ EGProject.............
    Or loose cable from battery.......
  4. starboy869
    starboy869 Senior Member
    You think $11 is kinda pricey for sparkplugs ???
  5. erikespo
    Western New York
    Heck yeah for OEM spark plugs. These aren't coming from honda these are just normal spark plugs
