Seany-izzle
Member
well people are going to have a hard time....
good luck hacking that system, or adding your own fuel delivery system
Originally posted by Car and Driver
Most cars have port fuel injection or direct injection. The new Lexus IS350 has both, in a twin-injection system called D-4S, to imporve low-speed and cold-start emissions. Toyota's new 2GR-FSE engine, a 306-hp, 3.5 litre V-6, has six pairs of injetors, one in each intake port and one in the cylinders themselves. During high-rpm, high-load conditions (stomping the throttle to pass, for example), only the cylinder injectors operate to maximize control over injection timing for better power. When the engine starts cold or runs at low-to-middle speeds and low-load conditions, such as cruising on the avenue, the injectors work together, varying their share of fuel delivery with conditions. The port injector induces better mixing at light throttleopenings. On cold start, the port injector and the direct injector and the direct injector work together to create a lean stratified charge that burns hot and lihts off the catalyst more quickly.
