200hp Zc?
Discussion in 'Engine Building' started by stud4u2c17, Mar 31, 2003.
  1. stud4u2c17
    stud4u2c17 Senior Member
    is it possible to start out with a 130hp zc motor for my crx, and put tons of money into it and get 200hp, can i do it with bout 2k? if i make a custom turbo kit (this is without nos 2) im wanting the ultimate sleeper car, with the ultimate sleeper motor!! thanks
    TJ
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    i think you should rethink your w/o nos part. it would be cheaper.
    why not get a swap and then turbo?
    custom turbo kits are way expensive, but they are the wayto go boost if you have the money.
    check out ks-motorsports.com
  3. civ90hb
    civ90hb Senior Member
    Waterloo, IL
    200 hp to the wheels or to the flywheel? My buddy is turboing his zc and doing a few other things and he estimated that he would gain about 70 hp with his turbo setup. He is making a custom turbo for it. Upgraded some things so the kit works better. He has spent i beleive $500 so far on his kit and he is about done with it. Needs 1 or 2 small things. So if you want i can let you know how it turns out.
  4. allm0t0rsir
    allm0t0rsir Member
    yes boost the hell out of it and you can get it to 200hp use a manifold from a hf crx for a turbo manifold get a 4g63 turbo get custom piping it can be done..get a safc to tune and dyno time :worthy:
  5. civ90hb
    Waterloo, IL
    My buddy is actually gettin his turbo on in 2 weeks now. Earlier than planned. So i should have info on his setup soon.
