brian11to1
see why...
what you cant see is all the little chunks of metal that fell out when i attempted to seperate the trans case halves...
i was coming off an off ramp to pick up my girlfriend. then, bam clank clishshhhhhhh. i sore either the linkage broke or I ran over a safe...
limped into the entrance to my g/fs work looked under the car and oil/fluid was draining out onto the ground.
when the tow service came, we had to literally drag the car up onto teh bed. it was acting like something was stuck in the wheels not allowing them to turn, every so often it would let loose and hop slightly...
some questions
1. the driver side axle is STUCK in the intermediate shaft... motherfucker. im debating on pulling it out to seperate it or leaving it alone for now...
2. should i replace the clutch or just the T/O bearing for now?
man... everyday is a new day...
