OK well as it says I'm going to install a 2nd alternator if i can this is my plan remove non working ac compressor and fab a bracket to run a stock alternator there. well bracket is done made it on old motor needs put in the car. OK on wiring i have some questions???????
1. Do you have to have the round 4 wire plug in a stock alt for it o make power.
2. Is it going to mater if one is putting out a different voltage that the other. say 13.1 on one an 14 on the other.
3. Are 2 4awg power wires good enough for a combined total of 1500 watts on good amps
