NotUrAverage_Si
Quick question for you Brian.
After wiring in the new MAP sensor did you check the voltage with a multi-meter to make sure it was correct like hondata suggests? I want to go ahead and wire mine up but I don't have a multi-meter to check my work afterwards. Just wondering if I need to do this.
http://hondata.com/3barinstall.html
Installation seems fairly easy.
