3 bar map sensor
Discussion in 'ECU's, Electronics, and Tuning' started by formby, Oct 25, 2005.
  1. formby
    formby learning in progress
  2. pissedoffsol
    just unplug your stock map sensor, and splice it in. give the gm a vac source from the manifold. its 3 wires just like ours is.
    green plug:
    wire colors are lettered: see the post-it pic above...
    GM sells a pig-tail too... the sensor won't come with it- i suggest you buy it.
    lol, sorry i went picture whoring.
    as far as the computer is concerned, just make sure you set the turbo edit to run off the 3-bar, and its done.
  3. formby
    called gm...
    the green map plug (pig tail) part # is 12085502
    and the map sensor part # is 12223861
    thank you B...
  4. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    I know vafc are no good, but can a 3 bar map sensor be used with a stock ecu and a vafc??
  5. formby
    no...our ecu's are n/a and dont know what to do with the read outs.....so you need an ems
  6. pissedoffsol
    werd, since the voltage range is still the same, 0--5v for WOT and 0% throttle, the increments are way off. the oem ecu won't know what to do with the reading of 1 volt expecting, say 100 cfm of air, vs the 3-bars 1 volt signla when theres 200 cfm of air.
    just numbers for example here...
  7. formby
    this should be a sticky
    :ph34r: :ph34r: :ph34r: :ph34r:
  8. pissedoffsol
  9. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    so its impossible, just wondering I have turboedit i was just wondering
  10. formby
    okay...TE is an ems...if your ecu is chipped just have a chip burned that reads the sensor...or i would buy an ostrich from http://www.moates.net.....and make the change
  11. 4drcivicb18a
    4drcivicb18a Member
    philly, PA
    I know, I have turbo edit and a 3 bar map sensor works fine, but i seen this thread and remembered a friend with a vafc was asking if it was possible to use a 3 bar map sensor with his vafc. sorry for the complication
  12. pissedoffsol
    stock ecu cannot use it. you need to have a program that can read and intrepret the 3-bar voltage range, such as a chip
  13. formby
    62 bucks baby...
    but its ac delco
  14. pissedoffsol
    cool. just make sure its not the 2.5 bar.
    you got it for the 89 Trans am 3.8 v6 turbo right?
  15. formby
  16. pissedoffsol
