300 hp b18a crx turbo build
Discussion in 'Forced Induction' started by ryangt, Jan 10, 2007.
  1. ryangt
    ryangt Senior Member
    I have a 91 crx with a 91 teggy b18a with a ys1 tranny. I want to build a 300 horse motor, its just my goal.
    Im not sure what i can do to most easily reach this goal.
    Turbo kit? If so what do i need to do this right the first time.
    lsvtec all motor? What will i need
    anyones help would really be appreciated. I dont want to spend tons of money over and over, i want to build it one time, RIGHT the first time.
    please be as specific as possible
    thanks in advance.
  2. ryangt
    also if this helps, the car is not my daily driver, so i dont care if its getting 30 mpg or the idle lopes, just so long as its manageable.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Turbo. 300whp all motor on a B18 isn't realistic on a street driven car.
  4. ryangt
    i figured as much, what would be my best way to build a reliable turbo setup for that sort of power?
  5. phunky.buddha
    Find the right size turbo for your preferred power curve, bolt everything up, then tune tune tune!
  6. ryangt
    whats a good turbo to work with for that kinda power?? t3 t4 or what?
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    A t04e 57trim cold side is going to be your cheapest turbo that will make the power within the compressor's efficiency islands. I'd go with a t04e 60 trim compressor with a .63 A/R t3 hotside. A gt28rs might get you there alright, but it will spool a bit faster, so you'll likely make more power under the curve with it, but if you are looking for an inexpensive way, just go with the hybrid t04e/t3 snails I listed, and, combined with the right support components and tuning, you'll easily hit your goal without overworking the turbo.
  8. CRX Si-R
    CRX Si-R eat my shwartz
    Northern Virginia
    exactly the GT2871r is going to be in my LS turbo setup. Those turbos are good for the 1.8-2.2 liter range.
  9. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    i would go with something alittle bigger then gt28. i mean if you dont plan on wanting more power go for it but there not cheap to just upgrade.
  10. vtec777
    vtec777 Junior Member
    gt 3540 turbine......:)
  11. piggy96
    piggy96 New Member
    Aurora, Ontario, Canada
    im building an ls turbo, after all my research i've decided on a t3/t4 (from garrett), mainly because u will still get a decent spool time and has a wide power range (good for 300-550hp)
  12. floridachill71
    floridachill71 Lean and Mean
    J-ville
    jdm gsr w/turbonetics t3/t4 cbb. couldnt be happier
