3rd gear grind on and off
Discussion in 'General Tech and Maintenance' started by civicdx92, Feb 24, 2005.
  1. civicdx92
    civicdx92 Senior Member
    MN
    ok so my 3rd gear has a grind above 4500 rpms and it is probably the syncros that r shot, but how abou after 2 months almost of that happening, 3rd gear shifts just fine with no problems? i was going to buy some synchro mesh fluid and now my car shifts fine so i dont know what the hell is the problem...any help appreciated.
  2. civicdx92
    MN
    any1?
  3. Taco15
    Tallahassee Fl
    i have the same problem with my rex. I was told to either get another tranny or fix 3rd gear. But i have to ask, what is syncro mesh fluid and how does it work? I might try that before i spent all that money.
  4. david_jones001
    david_jones001 Senior Member
    Arizona
    mine does that two in 3rd, it doesnt it if i just put it in gear without thinking, but if i carefully , then its doesnt, but it doestn really grind, just like a little grind,
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    use the fluid it will help sound like the syncro is going to hell
  6. civicdx92
    MN
    taco15 syncro mesh fluid is a product made to neutralize that tiny grind in ur tranny. i personally havent used it but alot of people swear by it so i think im gonna give it a shot to see what happens
  7. Taco15
    Tallahassee Fl
    let me know how it feels . I usually just skip 3 and go straight 4th but it sucks when you want to punch it. Also does that mean that i have to change the tranny fluid more often? I mean everytime it grinds im sure some shavings come loose..right? I'll admit, im not the smartest when i come to DOHC VTEC since this is my first one. also first time having this grinding problem also.
  8. formby
    formby learning in progress
    mine did the same thing , i bought the penzoil syncro mesh and it lessened the noise.....the GM brand is the best.....but its def the syncros....hondas are known for syncro noise
    i dont know what syncros are needed for a S1 b16 cable tranny...or where to get them.......i think 99-00 b16/SIR syncros will work....i already know about gear speed..... but any others??????
  9. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Just try shifting a little slower. My ls grinds 2nd and 3rd, but only if I try to force it.
  10. david_jones001
    Arizona
    lol its just a pain in the ass cuase ur riping threw the gear and then u gotta shift and back off slowly switch it then rape it again lol
  11. Taco15
    Tallahassee Fl
    so the mesh fluid helps prolong the life right? if so the shit,i'd better hit autozone asap.
  12. Jeef
    Jeef NO MA'AM Moderator VIP
    Using the fluid will not fix the problem, it just lets your drive around longer with it. Honda MTF has helped me with this problem in the past. I got about 2 years out of the tranny in my civic until it didn't want to stay in gear anymore.
  13. Taco15
    Tallahassee Fl
    well yeah i know it wont fix the problem. but my tranny is pretty expensive and want that bish to last. is that fluid an additive? how much do you put in the b16 tranny? thats about all the questions i have.
  14. hcivic.com
    if anybody needs tranny parts pm me and ill get you parts and a price
  15. civicdx92
    MN
    i believe it should be mixed with ur tranny fluid. in my 92 teg that requires the removal of my passenger side wheel and taking a bolt out that exposes the oil...i should get this done soon. i noticed on cold tranny fluid it does ok but when it starts flowin it sucks.
  16. Taco15
    Tallahassee Fl
    thats about the same for my b16 tranny. I'm doing that as soon as i get some money.
  17. 4DRB16A
    4DRB16A Senior Member
    Near Kansas City, MO
    My tranny is starting to grind when I put it in 3rd gear. When I first start it in the morning while it is still cold and bring it to 4000 rpms and shift into 3rd it doesnt grind, BUT once it gets warmed up and I bring it to 4000 rpms and put it into 3rd it will grind slightly. This really annoys me, I just spent over $3000 to have this motor installed and only had it like 4 months and the syncros are already going out?? It doesnt do it when I am driving normal speeds and taking it easy, only when I race it. Man this sucks!
  18. brian11to1
    brian11to1 Senior Member
    No need for discussion just get some GM Synchromesh and put that shit in... it'll take about 100 or so miles for it to into the trans, but when it does you'll be happy.
  19. 4DRB16A
    Thanks! Man you guys are so cool and you answer questions quickly and correctly, unlike other honda forums that I have been to before that when you ask a question that have some smartass remark. (Hondahookup)
  20. 4DRB16A
    Alright last question.............How many quarts do I need? I think its an S1 tranny. I hit 5000 rpm around 80 mph lol.
