3rd Gear is being wierd
Discussion in 'General Tech and Maintenance' started by reikoshea, Jul 13, 2005.
  1. reikoshea
    Dallas, TX
    I dunno what is going on with my car, but i down shifted on the highway to catch up with my buddy in his maxima 3.5. When i hit 3rd gear i was at 4500 RPMs, which is a little bit out of VTEC, and as i accelerated, it felt like my engine was stalling (you know that little jumpy feeling that you get when you were first learning to drive a stick). Then it hit VTEC, and felt fine. When i got off the highway i decided to test it, and that only happends in 3rd gear out of VTEC. 1, 2, 4, and 5 are just fine. Is there any forseeable explination for that oddity?
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    ...only in 3rd.....
    I dont know but from teh symptom,s you described I'm willing to say you need to check your spark plugs and wires.
  3. Speedracer228
    Speedracer228 ......
    ^ what he said and also could be your fuel filter... a new one is mad cheap and makes a world of difference if yours is old dirty and never been changed
  4. reikoshea
    Dallas, TX
    all of the components you mentioned were changed about 3 weeks ago.
  5. B16CRX
    Greenville, SC
    I would go back and check them all. your ignition coil might be going bad too. I have never heard of a problem with bogging in a specific gear.
    Do you have your O2 sensors in place and hooked up to the ECU?
  6. reikoshea
    Dallas, TX
    yeah...apparently the shop that did my swap didnt change the wires like they said they did. Cyl 1 and 4 were all bubbly and crap. Changed the wires and its fine now.
