4-Speed/5-Speed SI Transmission HELP
Discussion in 'HYBRID -> ED-EF / DA' started by Draftinwitjr3815, Jul 4, 2009.
  1. Draftinwitjr3815
    Draftinwitjr3815 New Member
    Ok, I am looking to figure out which Transmission will be best for what I'm trying to do.
    Basically I have a 90 Civic DX Hatchback with a stock D15B2 and 5spd trans.
    I have a 4spd trans out of a 90 Civc DX and a 5spd trans out of a 90 CRX Si sitting on the floor.
    What I need to figure out is the Final Drive ratio's and gears that are in these transmissions
    I am going to race it on a 3/8 mile asphalt oval track here in NY and I need the trans with the longest 3nd and 3rd gear
    I can't find ANY information on the gearing in the 4spd, and I haven't had much luck locating any info on the stock 5spd.
    Any help would be greatly appreciated, thanks!
  2. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    what u should do is sell me that crx si tranny. i need one for a swap like really bad. the d15b2 will have longer gears. the si tranny has shorter gears obviously for acceleration.
    the si tranny has a 4.25 final drive. idk about the 4 spd.
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
  4. Draftinwitjr3815
    One question about that chart ^^^^^Above^^^^^
    The smaller the number the longer the gear correct???
    So I would favor a 4 spd trans because 2nd and 3rd gears are longer?
    Perfect, just the info I wanted!!! Thanks!
    Also, that trans is going to cost at least $100 to ship to you, not even sure where your located, so its not worth me selling it for only $50....
  5. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    I might be wrong, but you may need different axles to run the 4 speed trans. even if you'd want to.
  6. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    my si trans effed up and i swapped a 4spd in ..used the same axles
  7. Korax
    Korax New Member
    Western PA
    HF is the only one with different axles. It has a different spline count on the hub, or was it to the transaxle.. I forget..
  8. 95EGCoupeVtec
    South Mississippi
    i'm located at 39466, how much do u want for it? lemme konw i need it for a d15b swap into a 90 civic hatch. thx
  9. ahknodd
    ahknodd New Member
    Central Point, OR
    The HF has the same axles as the Standard Civic. The DX has the bigger outter hubs as the Si but the inner seal part on the tranny are different betweent he Dx and Si, so STD/HF axles are the same, DX are different, and Si are different.
    If you're racing oval I would think the DX would be best for you. As you can see in the chart the actual gears in the DX and Si are the same, the final drive is what makes the Si the most desireable for most people. The final drives are the same in the 4 speed and the DX, but I would think you'd want a bit of lower acceration. The 4 speeds are complete pigs. Yet if you're looking for the longest 3rd gear then look for an HF tranny.
  10. Draftinwitjr3815
    Thanks for everyone's help, I think I'm going to stick with the DX 5spd after all.
    As for the SI tranny I have, I've got a guy locally willing to pay $250 for it, so if you can beat that, remember to include shipping from 14212 to you.
    Thanks again guys!
  11. 95EGCoupeVtec
    South Mississippi
    hmm.....so $250 plus shipping? that's kinda high. lemme know if the local deal falls through. i think he'd be willing to pay $250 including shipping. idk u find out how much shipping would be n let me know.
  12. Draftinwitjr3815
    He's willing to pay me the $250 and come pick it up, no shipping needed, I'll let you know what happens.
    Its going to cost $105 to ship to you, so keep that in mind.
  13. jlicrx
    Colorado Springs
    DX and Si axles are identical - any of the axles will fit at the transmission end - all of the L3 transmissions, except for the ZC, have the same differential side gears where the axles go in - the ZC transmission uses an intermediate shaft and larger axles like the Integra - the large bearing transmission cases, like the Si, use a different seal than the small bearing cases, but the axles are all the same at the transmission end - the seals have the same inner diameter and different outer diameters
