pdqcrx
Member
run the wires from the o2 to the ecu. Now when I looked at the chart to see where to plug in o2 sensor ground D22,12v power A25, and heater control A6 there are already wires in the plug. Was this car even thougth its a one wire still wired at the ecu for the four wire system? Should I just pull the wires out of the plug and put the ones I pulled in their place?? Thanks
