450cc injectors
Discussion in 'General Tech and Maintenance' started by D See 2, Nov 13, 2002.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    if i get 4 DSM 450cc blue top injectors 90-94, what mods will i need to fit a honda fuel rail?
  2. rico2001
    rico2001 Member
    i asked same ? while back, no one answered. so i went out to find my own, and found that stock ecu can only handle up to 310cc injectors. with 450cc injectors/stock ecu, car will not hold an idle, it will stall. but if you are not in that situation (hondata or something like that), the injecters will have a very tight fit using stock injector seals but they will fit. some company, i don't remember which makes seal that have a larger I.D. than stock that will work well with the larger mitsu injectors. hope that helps and good luck.
  3. pissedoffsol
    and you need a resistor box....
    don't be a cheap ass.. by RC's
  4. rico2001
    rico2001 Member
    man what is that, a resistor box?
  5. pissedoffsol
    uhh don't quote me....
    but I THINK it makes peak and hold act as saturated... or vice versa... something liek that
  6. SolReaver
    SolReaver Senior Member
    the resistor box makes the dsm injectors have the proper impedance so the ecu doesnt burn out- and the ecu will idle the injectors...all you need is a device called a smc. I have never used it, but ive heard a lot of good things about. I think it would be good for someone that doesnt have the money for a hondata.
