450cc mitsu injectors
Discussion in 'Forced Induction' started by rico2001, Oct 27, 2002.
  1. rico2001
    rico2001 Member
    anyone know how or what it takes to install 450cc mitsu injectors in a honda. I've search and i can find any good site on installation. I have found sites of people who have done it.
  2. calvin
    calvin Senior Member
    NETHERLANDS
    can poist the sites
  3. pissedoffsol
    put them in
    lol
    you need an EF resistor box though
  4. rico2001
    rico2001 Member
    what do you mean? and what is this device?
  5. rico2001
    rico2001 Member
    hmm i found something out.
    Fuel: Most of the time 440cc injectors are good until low 300s whp. Anymore and 550s are needed. The biggest injector the stock ECU can idle is the 310cc. It will NOT idle 440s! A Zdyne or Hondata is needed to run these injectors.
  6. pissedoffsol
  7. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Where did you get your info from??? Well thats wrong! The ecu will handle the injectors! Its all a matter of getting a larger fuel pump and a FPR to push enough fuel into the injectors!
