I drove the car with stock injectors and stock computer with no boost to make sure the all wheel drive componets where working properly. No I didn't steel anything from him. Yes it's true I agent to jail for a month for unresolved traffic violations while I was in jail steve pickup his car . When I got out he told me his brake lines , oil cooler(that he was using as a fuel cooler on the return line) and fuel regulator where stollen. I wasn't there when he took his suff so I don't know what was or was there. He brought the car back because he couldn't find another shop to do the work. I bought him a new fuel regulator . I built him a complete turbo system consisting of turbonetics t66 ball bearing turbo with antisurge housing and ported t4 exh. Housing , custom manifold, 3 inch down pipe , tail 38 wastage,12x24x3 intercooler , 2 1/2" aluminum pipe ,silicon couples,t-bolt clamps, turbo xs bov, steel braid oil lines ,1600 rc injectors ,s 300 hondata, moved the fuse box,coil,msd to under the dash , and custom motor mounts for the all wheel drive.all custom fitted and installed for 5800.00 . I charge him 500 for a custom aluminum fuel cell installed.
Biulding the rear sub frame for the front suspension to go in the back mounting the 8.8 indipedent rear end installing the custom axles(I had made and assembled) ,brakes ( I bought) , coilovers( I bought), unfailing the drive shaft , installing the carrier bearing( I bought) , installing the custom Billiet adapter to the out put shaft (I machine) building the rollcage , installing the fuel pump and lines, making custom strut rods with himes and coustom mounts, making costum adjustable drag links for fear alinement . All that o did for FREE!!!! he only paid for the materials , my cost on materials not retail. I just didn't want to deal with him any more and now he's saying I sabotaged his car because his oil drain on the trans was loose and one bolt was missing in the transfercase . Well he brought me the trans and yes I should have checked the fain plug before I put oil in it , but sabotaze really .
