5 Bolt conversion on EG
Discussion in 'Wheels / Suspension / Tires / Brakes' started by BrowNKiD, Sep 8, 2004.
  1. BrowNKiD
    BrowNKiD Member
    Toronto, Ontario, Canada
    I want to convert my eg to a bolt... like a type r... how do i do this perferably using type y parts...
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Front hub, front LCA's, front sway bar and hardware, the rear LCA's and sway bar, the rear hub, calipers, brake booster and e-brake cables. I think you can also use some parts from the CRV. The JDM type R coversion requires you to get new axles. Doing this adds like 45 lbs to your car so it's not really worth it unless your doing it for the "bling".
  3. BrowNKiD
    BrowNKiD Member
    wat about uca? and im using usdm parts
  4. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    talk to eric (E_SolSi) if you want to know hes got the swap on his sol.
    -Chris
