brownkobe8
ok i understand that when im dropin the motors on the drivers side mount i need to grind off a bit to fit now i drive 96 lx now for it i just need to drop the engine and what do i need to modify on my harness out of the lx?
Also bout the ecu i need to wire vtec of course and then swithc a6 with a11 i think, but does this mean first i need to convert my ecu harnes to obd 1 then i switch the pins?
What ECU do you use for this type of swap
