im pretty sure you can
the rear lca's of the ITR use a differnt mount. on the EK, you need to use the CTR lca's due to the different length of the lca's. both have the other cou design instead of the outer fork design. so, jsut use your stock lca's instead of the tegs, and it shoudl bolt right up.
