gettocrx
Member
Hey guys! I was wondering what will my friend need to do this conversion in a integra! I know I'll need the trans, clutch pedal, clutch lines (w/master& slave), shift linkage, conversion trans mounts, clutch and flywheel (w/bolts) and a 5 speed ecu. I mean I did a 5 speed conversion on civics before, but I'm not sure if you have to change the rear mount bracket on the b series since it bolts to the trans and block? Does anyone know what else will I need? Thanks!
