5speed swap
Discussion in 'Civic and del Sol - EG and EK' started by skellagher, Dec 30, 2008.
  1. skellagher
    skellagher Elder Driver
    Newark, De
    ok so i bought my third eg and its an automatic, so my other eg just blew up so there is my donor car so i have every bit of everythign i need to do it i even pulled out the clutch line with out kinking it at all so i am good there my problem is when i get this all back together and all that what wiring is involved for the neutral and park switch? i have a p28 5speed ecu and all that i just simply need to know how i am going to get the key out of my ignition and to start. would be great to have detailed info on the wiring. i know how to do all the mechanical work i am just no good with wiring. i have the swap trans mount from innovative mounts as well so all i need is those two wiring woes there resolved before i get this started this week end and i will make sure to take pics and possible write up a more detailed article on this swap so there is not so many questions. ps i also have the entire engine harness from my donor car as well if there is anymore wiring from the donor car i need let me know please before the salvage yard comes to get my car.
  2. skellagher
    Newark, De
    c'mon guys i would just like this info before i actually start so i dont hit a runt in the road while i am doing this.
  3. sernmd
    sernmd New Member
    do you have the haynes manual?? it give you the wire diagram for the automatic if not il run to my car and see how i did it post back soon
  4. serrilion
    serrilion In my own little world! VIP
    Vermont
    Hey Bud... this link should help u. Just fallow it, I did an entire swap on my 95 Coupe along time ago... like when I was a newbie to hondas... Just remeber ya need to run the reverse light wires and yep heres the link... Good luck, btw have a big pale for the auto trany fuild there is a crap load!
    Rywire - Online Store
