Matthias Meyer
I just finished dropping a D16Z6 (SOHC VTEC 1.6) into a cx civic (SOHC non-VTEC), i used the cx wiring, due to this, i have no wiring for the MAP sensor on the top of the intake manifold by the throttle body, should i just go directly to the ecu, if so, what pins should i use, aso there was a vacume line on the cx intake manifold which is not on the SI manifold.
Also, what should i do with the VTEC oil pressure sensor, if i should connect them to the ECU, what pins should i use, and one more thing, which pin is used on the SI ECU to activate the VTEC.
PLEASE HELP, Thank You in advance, any links would also be appreciated.
