6 flashes and then 6 more?
Discussion in 'ECU's, Electronics, and Tuning' started by YouKnowWhoIBee, Mar 26, 2004.
  1. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
    I have a sohc 95 civic hatch. And i was throwing a code like once everyother day. So i found out through a friend that on sohc 5th gen civics you use the peper clip to see the code you are throwing. So i did it and i counted the flashes on the cel. It flashed 6 consistant times then paused and then 6 more flashes. So does that mean the code i am throwing is 6 or 12? I thought it was 6 which meant "engine coolant temp"( i think) But i dont know what to do about it. If that is even the code i am throwing. So can anyone help me out. Thanks in advance :worthy: [HS]
  2. HardLowrdRanger
    HardLowrdRanger Member
    Phoenix, AZ
    6 quick flashes then a pause would be 6... If there's no other codes it will just keep doing that over and over... So you got it... Now fix it ;)
  3. YouKnowWhoIBee
    Maryland
    I plan on it probably tomorrow. i know it is located on my block below my dizzy. If that is my problem. Does anyone know off hand how much ect sensors run?
  4. tab
    tab Super Moderator
    Aberdeen, Washington State
    $40 maybe? I don't know how much for yours.
  5. Projectzc
    Projectzc Senior Member
    Or you can steal one off an old head or go to a junk yard and grab a few throw it in you pocket. The Jersey way.
