62-1 and B16a
Discussion in 'Forced Induction' started by Johnnylawless, Oct 9, 2005.
  1. Johnnylawless
    Johnnylawless Senior Member
    anybody using this setup or similar, all I keep finding is 1.8l and higher with this turbo
    84mm B16a
    ge hd sleeves
    type r head
    H beam rods
    turbonetics 62-1 stage 5 turbo
    Any HP numbers from anybody running similar setup?
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    what's up Jim, good to see your motor is coming back together for like the 6th time in 1 year :p [​IMG]
    as for the HP #'s, depends on what compression you are running because if you're too low, you'll have to make up the loss in power with boost, that being said, Jeremy had that turbo on a stock GSR block @ 8lbs on Hondata. If I remember correctly he made like 320whp. Hope this helps.
  3. Johnnylawless
    Hey what up,
    Actually for this motor (B16a). It's only the first teardown,hopefully I get the new slugs next week.
    and the hone.
  4. pissedoffsol
    what compression b16? under 9.5:1 that thing is going to be real laggy...
  5. Johnnylawless
  6. pissedoffsol
    well, it would def not be my first choice... but if you already got it, go for it.
    it will be a killer at the track, but around town its going to suck ass.
    i'm guessing 12-ish psi will come on around 6000...
  7. Johnnylawless
    Right on the money 6K
  8. pissedoffsol
    ok, so what exaclty is your question?? jsut wanted to see some numbers?
  9. Johnnylawless
    Whp #'s
    Dynos of similar setups etc etc
