68mm TB on Skunk2 mani! What TB gasket do I need?
gocivicls
I have a GSR motor with a Skunk2 mani and a STR 68mm TB. What TB gasket do I need to get. Type R's are 67mm right.
Let me know where to purchase also, THanks!!!!
:worthy:
here's a shot in the dark because i haven't done this and i'm prolly wrong- but i would just buy the regular one and then trim it with a razor to fit the larger tb
how about going to napa and getting a piece of uncut gasket material- and then cut your own??
they are either lying or it is a type r TB that has been bored to 67mm.
Originally posted by gocivicls@Oct 21 2003, 02:39 AM
prob. bored!!! Too good to be true, a honda w/ factory 67mm TB!
Sorry, guys!!!!
Yeah, that and you said that you wanted a
68mm TB on skunk2 mani!
in your thread title. ;)
i dont think its bored out. the wals are too thick for it to have been bored out, they would be super thin to bore from 62-67. its probably aftermarket, but it sure does look stock so i dunno.
and sleeper, he said he HAD a 68 mm TB, not he WANTED one.
Just use some gasket maker. I have an Erics racing 70mm TB, thats what they recomended to me. Just use a thin layer by applying with your finger. Put TB on, hand tight'n it, wait for gasket maker to semi-cure then tourqe TB down.
