68MM Throttle Body for $99 plus FREE Shipping! Doesn't get any better then this!
Status
Not open for further replies.
Hello HS Members!
We are new to this community (have specialized in this industry for 11 years) so wanted to start off with a bang!
Here is a SMOKIN' deal on an OMNI-Power 68mm throttle body for $99 shipped!
Omnipower 68mm Taper Bore Throttle bodies are 8mm larger in diameter than the OEM 60mm Throttle body. This results in a much larger opening for incoming air and dyno proven 12-15 WHP gains (modified engine with port matched intake manifold opening). Omnipower Throttle Bodies are OEM quality castings which appear stock to the untrained eye. Each Omnipower Throttle body comes with a New gasket, and is a direct bolt on to the factory intake manifold.
Why Cast vs Billet?
As regulations become more and more strict, law enforcement is targeting modified vehicles. Omnipower Cast Throttle bodies look and function like stock to the average Joe, where as a billet Throttle body sticks out and will quickly become a ticket magnet should you get pulled over.
Key features:
OEM Quality Casting and Appearance
Larger Than Stock
12-15 WHP Gains
Includes New Gasket for Easy Installation
Add a Genuine OMNI-Power Throttle Position Sensor for only $69.99!
Throttle body comes with new gasket and will fit:
88-00 Honda Civic (some models require an aftermarket intake manifold)
90-01 Acura Integra RS/LS
90-01 Acura Integra GSR (requires aftermarket intake manifold)
97-01 Acura Integra Type-R
92-01 Honda Prelude
90-02 Honda Accord (98-02 4-cylinder only)
Note: Taper bore specs are 69mm inlet down to 68mm outlet.
Click Here to purchase or for more info.
bought one frm ebay a couple months ago works great.
Thanks, eg6sir and INJEN78, these are some awesome throttle bodies and we're proud to go through so many of them!
About the only thing we sell more of every month than these are the matching Omni Throttle Position Sensors!
Not bad of a deal.
Portmatched is a must if you want maximum & optimum performance gain from this TB.
nusdogg has it right. Bolt-on upgrades are only as good as the bits they're put on. If you do your research and get the machine work done, you will be even more pleased with the results!
Orders shipped (to such exotic places as CA, MN, FL, and Germany so far this week) and PMs replied! Thank you for the continued interest!
Just wanted to mention that these do have a cast finish. The only machined piece is the throttle plate itself (the butterfly). The bore is cast (rough, no machining marks) and it's kinda tough to tell these from stock. Want it looking really stock, rub some dirty oil on the outside and spray it with WD-40 or something.
Orders shipped and PM's replied. Thank you for your business!
Orders shipped, PM's replied, and live chat now available if you have additional questions while you're on our site!
Status
