6th Gen Ex Ecu In Dx W/ex Intake Manifold
Discussion in 'ECU's, Electronics, and Tuning' started by sephion, Mar 21, 2003.
  1. sephion
    sephion Junior Member
    if i put the ecu from a 6th gen civic ex into a 6th gen dx civic with the ex intake manifold would i gain anything, are there different fuel and ignition maps? would it not work above vtec engagement rpm? what kind of troubles might i run into? thanks
  2. solblu
    solblu Senior Member
    Ricer
    I think the OBD2 ECU's have a limp mode for certain CEL's. you would probably be stuck in this limp mode. The Y8 intake manifold is a good mod though. Your DX ECU will modify the amount of air and fuel it uses after you do the swap.
