6th honda civic gsr swap
Discussion in 'HYBRID -> EG-EK / DC' started by 4drteg54321, Nov 29, 2008.
  1. 4drteg54321
    4drteg54321 New Member
    Okay, I swapped a Obd1 Gsr in a Honda Civic 1998 EX. i did all the wiring. Am using a obd1 alternator and obd1 distu from my gsr. I also did the Crank sensor bypass. Here the problem the car will barley try to start i have to crank it a few times, when it does start it will idle a bit and then it will die when i push on the gas pedal. what cause this? Also am still running the obd2 ECU that came with the civic. Even using that Ecu wouldnt it still Idle?
  2. 4drteg54321
    anyone?
  3. D16SiHatch
    D16SiHatch New Member
    obd# of dizzy has to match the ecu. so yea thats probably why its runnin like crap
  4. 4drteg54321
    still having a problem even using the jumper harness, but this time it actually worked once. the car ran like normal intill i try to crank it back up again
  5. tabKola
    tabKola New Member
    Tewksbury MA
    An OBD2 D16Y8 ECU will not correctly run an OBD1 GSR engine. Pick up the correct ECU with matching wire harness.
