CivicRiderX
listed on ebay
750cc injectors on eBay (end time 27-Jun-10 21:39:24 BST)
Specifications:
Flow Rate 750cc / Min @ 43.5 psi
Flow Rate LB 72LBS / HR @ 43.5 psi
Resistance 12.5 ohms @ 68F
Voltage 8-15 Volts, nominal 13.5 Volts
Amperage; 1.0 Amps
Pressure min 30 psig / max 100 psig
EV1 Injector Connection
Measurement:
Height: 7cm
Specifications:
Amperage; 1.0 Amps
Measurement:
Height: 7cm
