77 Civic Swap - CVCC to D16A1
Discussion in 'Auto Multi-Media' started by JC777, Jun 4, 2018.
  1. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    also thank you .. your build lit a fire under my ass because you started after me and had the motor in before me haha... I just kinda caught up and then some
  2. dilbeckskate
    Kennesaw Ga
    also if want to stay obd0 and that harness etc good luck staying finding another vac advance dist or repair parts id at least convert to obd0 and put a electronic advance dist in it and a blacktop ecu (I have a pm7 blacktop ecu id sell) , you can delete all the vac stuff also other than the map sensor and the vac advance or if go electronic advance (just a distributor and ecu swap) you only need vac going to the map sensor
  3. dilbeckskate
    Kennesaw Ga
    ive also got a blacktop intake manifold that flows way better than that brown top intake manifold id sell too
  4. dilbeckskate
    Kennesaw Ga
    oh yea you also would just have to swap to obd1 injectors and a obd0 or obd1 distributor (ive got spares)
  5. JC777
    JC777 Member
    Bend, Or
    Thanks for all the input.
    I would be curious to find out how much the jason watters set up would set me back and im also curious how much youd sell them parts to me for.
  6. dilbeckskate
    Kennesaw Ga
    I think the harness was 700 and the ecu with hondata s300v3 is another 700 but the misc zc stuff id sell relatively cheap
  7. JC777
    JC777 Member
    Bend, Or
    Im gunna focus on completing what i got to first but I am def interest in getting those parts from you and getting the harness and hondata setup. Once I get closer Ill def be hitting you up.
    dilbeckskate likes this.
  8. JC777
    JC777 Member
    Bend, Or
    Even tho the CVCC looks like its guts are hanging out everywhere, its alive! My cousin was there the hold the car in place and make sure it doesn't go anywhere. Lol Its actually quite helpful having some one there to drink with.
    Got it running Friday night, I will just be removing one wire at a time and making sure it still fires up untill only the necessary wires remain.
    Once I get the D16 harness stripped, Ill move on to the Honda harness and merge the two into one.
  9. JC777
    JC777 Member
    Bend, Or
    Just out of curiosity, does anybody know what the box on the left or the part on the right does? IMG_20190203_171523.jpg
  10. TurboMirage
  11. dilbeckskate
    Kennesaw Ga
    great work yes, lol its funny how every swap is a little different when fabricated and wired in like this and how you are approaching things vs I am , I personally said fook all the chopping down factory wiring I didnt want to deal with the fuse panels and dash/door wiring, it should be fairly simple to combine the harnesses you will leave the chassis wiring alone and just tie your 12v constant wire with your engine 12v constant power
  12. JC777
    JC777 Member
    Bend, Or
    Yea im def excited to have it running.
    I suppose my real wiring question is, can all electrical components be removed other than the fuse block and ECU? Or does the ecu rely upon other components to still run the motor correctly?
    I have unplugged pretty much everything but the ecu and fuse block and the motor still runs but i haven't ran it longer than about 30seconds since the radiator is not yet installed.
  13. dilbeckskate
    Kennesaw Ga
    the ecu only relies on data coming from the sensors on the motor, the hard part is lopping the harness down and matching wires on each side of the fuse panel on what needs 12v and 12v switched and ground , the pain in the ass part if you are wanting to delete all that jazz is messing with the main relay etc, it would be easiest to use minimal wiring from that harness to make it run and add your own fuel pump/wiring etc to eliminate the main relay , I looked into doing all this with a chopped down crx harness was my original plan and ended up being a huge headache
  14. JC777
    JC777 Member
    Bend, Or
    Right now im using the cvcc wiring to run the fuel pump. Might keep it that way.
    Got my radiator fan today and got it installed and the hoses hooked up.
    Unfortunately I wont have a chance to work on the car this weekend. But next week Im hoping to get my intake installed.
    Matts96HB likes this.
  15. dilbeckskate
    Kennesaw Ga
    nice ! and im running my fuel pump relay trigger wire off the stock chassis wiring soo key has to be in and on for fuel pump to turn on and and unlock the steering wheel and my ignition and fans through my switch panel soo still has some kind of theft protection . Keep up the work man im picking up some ruper rare parts for mine this weekend
  16. JC777
    JC777 Member
    Bend, Or
    I wish I could find a doner car so i can get some interior parts and front & rear bumpers. Perhaps I'll search harder after I have it running and driving.
    Getting closer tho. Got my intake built tonight.
  17. dilbeckskate
    Kennesaw Ga
    lol I thought about doing my intake like that after seeing another car with it
  18. JC777
    JC777 Member
    Bend, Or
    Forced cold air for under $100.
    The only down side I can think of, is that its its gunna be loud inside the cab.
    But Im not concerned. Lol
  19. dilbeckskate
    Kennesaw Ga
    lol yea but its functional and I want to do it for the sound im building a mf racecar
  20. JC777
    JC777 Member
    Bend, Or
    Got some new parts on the front installed:
    New rotors, rebuilt both hubs, new lower control arms and new tie rod ends.
    Now im just trying to figure out axles
    Any input is appreciated. My current plan is to have a local shop splice the 77 axles to the 87.
    Im aware having them modified in this fashion weakens the axles but im counting on the thicker 87 axle shaft and the weight reduction of the 77 to make up for the modification.
    Jeef likes this.
