800 bucks and dont know what to do to my b20 teggy
Discussion in 'Integra' started by competitiveaudioman, Sep 23, 2007.
  1. competitiveaudioman
    competitiveaudioman New Member
    i have $800 and a jdm b20b in my teg with basic bolt ons including, arp headstuds, block guard, 4.2.1 header, 3" exhaust, cold air intake, and a fuel pressure reg. what can i do to help my hp with 800? there way to many options and i dont know which one to take..turbo, vtec head, nirous or build to high compresion. its my daily and i want it quicker. HELP asap PLEASE!!!!
  2. get_nick
    Washington State
    NAAAWWWWSSSS!!!!!!!
    save your money. if you are into racing, you'll need it down the road.
    if it truly is burning a hole in your pocket, i say LSD, good tires, upgrade the suspension. something along those lines. maybe even some new brakes.
  3. competitiveaudioman
    yeah but i want speeeeedddd lol. no really for the track just everyday driving. and id love to do the naaaazzzzz but people are saying that it would kill my engine:(
  4. myah
    myah Neu Impact Performance
    ks
    one word vtec yeah man get a b16 head and go b20 vtec it will make your top end so much faster
  5. competitiveaudioman
    dont i have to build my bottom end to do a b20/vtec?:driver:
  6. myah
    ks
    not really just new water pump and oil pump and golden eagle ls/v kit
  7. 99sidude
    Ohio
    +1 for a vtec head. You don't need to build, just keep the rev's under control
  8. competitiveaudioman
    yeah? would a stock gsr computer get me on the road the right way?
  9. 99sidude
    Ohio
    A stock gsr computer is going to rev out to 8200 rpm's, which is more than the stock b20 can handle. Plus, a b20 is larger than a b18c1, which means it gets more air, and hence, needs more fuel. I think a p28 ecu with a custom tune would suite you best.
  10. competitiveaudioman
    ok ok. is the b20/vtec gona have a beter hp gain then lets say 10psi boost? that was the rout i was going but im up for anything.
  11. 99sidude
    Ohio
    hell no... 10 psi of boost on a b20 will get you roughly 250-300whp depending on setup/tune. A b20/vtec will yeild 160-170 at the wheels stock.
  12. get_nick
    Washington State
    10 psi wont get that much power. maybe 240 or so, but nowhere near 300. if you are wanting speed for daily driving, just get a good tune and a few bolt ons. i also suggest going to a driving school. that will make you faster than any mod could ever do.
  13. 99sidude
    Ohio
    Really? people make that much on boosted ls's. Why not a b20?
  14. competitiveaudioman
    well my b20 has stock internals so if its anything like the ls there good for 270-300hp on stock bottom end. i wouldnt want to risk it anymore then 13 max 8-10 everyday. well if its that much more power gain then im going to turbo it. im going for a fast car so its sounding like boooooosssssttttt
  15. formby
    formby learning in progress
    the sleeves
    what tranny do you have?
    i would invest in a gsr w/lsd
    and why the 3" exhaust. i bet you would see a gain from going to 2.5"
    buy the 84mm gsr replica pistons and nice cams if you want to stay mild NA
  16. competitiveaudioman
    well right now i have the ls tranny with a stage 3 puck clutch and 9lb flywheel. gsr tranny would be nice but i just got my ls rebuilt so im going to run that for a bit. as for the exhaust i know that was alittl exessive but my buddy had 3" on his single slam jrsc and it did quite well so i figured bigger motor, more boost so i would run it also. puting gsr pistons in a b20 is the same concept as b16 pistons in a b18 right? higher compresion? also is the block gaurd a good thing to have on a b20 or is it pointless?
  17. Dasfinc
    Dasfinc New Member
    with that transmission and that exhaust, boost may not be a bad idea.
  18. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Short gears are always better. For boost, just swap in a LS final drive.
    I vote VTEC head, or just camshafts for your B20(like Crower or Crane)+tune, or transmission.
  19. Dasfinc
    Dasfinc New Member
    Keep in mind he just had the tranny rebuilt and has a decent clutch and flywheel, an LS Tranny would be just fine with a small amount of boost, no need in replacing his tranny again if you ask me.
  20. K2e2vin
    Raleigh, NC
    Well, he did ask what he can do to improve the performance; and replacing the transmission is one of them. I've also suggested some other things he can do; keeping the $800 limit in mind(anything you replace could be resold anyways).
    Also, his car isn't boosted right now; so a better transmission would indefinitely make a noticeable difference.
