importimage
I plan to rebuild the bottom end of my B20B this winter. I am going to get the block resleeved and upgrade the pistons.
My question is, should I go with the 84mm sleeve and piston combo? OR should I go with the 84.5mm sleeve and piston combo?
What pistons would you recommend for the B20B Vtec Turbo setup???
