86 crx dx no spark need help
aaronchase99
well im not getting any spark and have never had such a problem figuring out why not. it has a new coil icm plugs wires rotors and cap. all the grounds have been checked out and are good. no check engine lights on. i double tested the new coil for ohms they where good. ( dont have the numbers right on me) the icm gets 12 volts to both wires. the rotror spins when cranking so timing belt in tack. could it have jumped and have no spark or would it have a weak or just timing of spark off? it gets fuel so the main relay should be good. any where else to try? new to this fourm and hondas tryed a fourm the other day with no replys so if anyone could help thanks
